Light switch wiring question | on ElectriciansForums
Guest viewing is limited
Discuss Light switch wiring question in the UK Electrical Forum area at ElectriciansForums.net
Sunderland
Hi. In regards to a 1way light switch that has a loop installed at the switch can I simply install a new switch and put the loop wires in l2 and the switch in l1?
[ElectriciansForums.net] Light switch wiring question
If you do that, it will not work, ever.
Where do the 'loop' wires terminate at the moment?
What colour are these 'loop' wires?
Some switches have a terminal marked ‘loop’ which is where the neutrals are connected to. This terminal has no function for the switch and is simply somewhere to park the neutral wires.
If your new switch doesn’t have this, use a bit of connector for the neutrals.
A photograph of the existing switch connections and all the cables at the switch would help us give you more accurate advice.
What you have there, is a 2 way switch.
Depending upon the switch position, you will have continuity between either L and L1 or L and L2.
If you were to put the permanent live into L and the neutrals into L2, whenever you switched off, your fuse or MCB would blow or trip. All your lights would go off.
You could feasibly put the permanent live into L1 and the neutrals into L2.
I would not recommend doing such though.
Some people write replies without thinking of the consequences of what they are writing, this is part of being an electrician is you understand how all the component parts work, I read a post the other day, “on how do you do a rewire” crazy that we even reply to these people especially the general public.
Further to the comments “what you have there is a 2 way switch” all one gang switches that are enhanced, chrome, satin, etc are nearly always 1 gang 2 way, find out the facts first then you can give advice that fits the situations
It is a fact that the picture showed a 2 way switch. Not sure what you are getting at here?
Reply to Light switch wiring question in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Thanks again for your help, now solved 👍
Recommended Sponsor News
Hi everyone,
