View the thread, titled "Lightbulb madness" which is posted in Australia on Electricians Forums.
J
jim_jimmy
Went to a job last week with the client having a problem with her lights blowing. Thinking it would be a simple fault somewhere on the circuit off i went with my tester and knocked on the door. When i got there, no fault anywhere, however she goes through about 40 lamps/bulbs every month! Any idea why this is happening? Confusing me!
Cheers.
SNAP. About a year ago I was called to a similar problem. The owners were going through about 30 – 40 lamps per month. I went through all the usual stuff of suggesting better quality lamps, but they had already done that and it didn’t work so they went back to the el cheepo B&Q lamps, I tested the circuit, tested the neutrals etc etc etc checked the voltage time and time again on each occasion it was fine. Anyway I ended up fitting a voltage recorder and leaving it for 2 weeks. When I looked at the results it showed regular voltage dips to around 138 and peaks to around 275. After a lot of messing around I discovered there was a sewage pumping station around 50 meters away and when the pump started and stopped the voltage dipped them peaked when it stopped. Problem found…but still not sorted.
Ian
Reply to the thread, titled "Lightbulb madness" which is posted in Australia on Electricians Forums.
