View the thread, titled "lighting circuit identifying earth on old wires" which is posted in Australia on Electricians Forums.
N
nick.appleby
Hi all.
Am trying to replace switches and wall leights and ceiling lights i have identified live and neutral (black and red)but what appears to be the earth is a grey colour also its not wired to the earth terminal but to one of the Com connectors. Does this mean that there is no earth wiring or has it been wired wrong, could really do with a quick response please help
Nick
if i dont use any metal fitting ie switches sockets or pendants and use plastic will it be ok to use plastic without the cpc many thanks eveyone first time here and the advice is brilliant cant thank you enough
it definetly needs a re-wire and your right about the board the prblem is the current fitting are metal just want to make safe before the re-wire
In my opinion mate,i would get the property rewired.Is it your property or are you doing work there.
Reply to the thread, titled "lighting circuit identifying earth on old wires" which is posted in Australia on Electricians Forums.
