Anthony - I can see what your original question was trying to aim at but you barred us from using any calcs and only rule of thumb, considering you have stated singles then surely you must realise how this singles is contained and grouped has a very big bearing on the answer even for an approx' rule of thumb or experienced guess.
Example - if the containment was metal with a good surface area and provided a designed earth path then compliance with ELI would be less of a worry, volts drop also has some flexibility at the installers discretion.
Yes of course you would follow up with calculations and I was referring to one type of circuit as many electricians on here must of installed at some point. If on a proposed circuit chart it is shown 1.5 and you are looking at the run and you are going to be more than half of that drum to the first light in that room past experience/thoughts go through your mind to rethink/check.
This is why I believe you asked a question that was relatively difficult to give a straight answer to given the lack of info, and why you got probed for more info' - if I was to browse using my experience and judge such an install in order to make a guess (no calcs) then I would still take into account installation methods in order to weigh up a reasonable guess, it can make a big difference to the guess.
