R
Richard3009
When installing loads of lights in a warehouse, is it common practice to use lighting contactors driven from a standard light switch, what would a typical installation on a large scale consist of.
Discuss Lighting contactors in the UK Electrical Forum area at ElectriciansForums.net
What’s wrong with one light switch for 120KW of lighting?
Nothing if your supply is up to it and you aint gonna dip half the neighbourhood when you press it
Fair enough mate. It is also the reasons you state in the quoted post that I was reluctant to post up much more with regards as to how the op should tackle the job. If the op has no experience of even installing high load factory lighting then he really should be referring the job to someone who has (No disrespect intended to you OP...you could always tag along with the other electrician as it is like riding a bike...you never forget and from what you have written so far you seem to know in theory what you need if just a little unsure how to tackle it).I assumed in asking the question he hasn't experience in the design concept so if its an area he's interested in he would need to work along side someone who has experience or look into taking a course .... wasn't saying the course is the only route their are other ways hmmmm yes my post did read that way though ooophs!..
TBH Ive seen lighting circuits designed wrong so many time by even experienced industrial sparks it beggars belief, telling a older spark who has pride in his work that he's designed the lighting wrong is not an easy thing to do .... denial and the more experience than me attitude is a hard wall to get around.... well until I prove things...TBH an advanced course wouldn't go a miss for a lot of them.
You seem confident Diddy and mostly likely its a breeze for you but surely you must have seen a lot of bad designs over the yrs not to mention sparks working in fields out of their depths... I know I have, I usually am the one that gets called out to finally resolve problems after in-house sparks etc fail to do so and I always end up ruffling a few feathers in resolving the problem.
That sticker requirement is no longer required it was dropped a while back and only applies where you have over 230v to earth so not a set-up found behind any light switch really even with 400v present. Yes E54..... they took out the need for a sticker :willy_nilly:woo hoo!
are you sure they were not a member on here lolI'm gutted! I think stickers add to the aesthetics of a job, until some pratt put 6 on my CU!
If it hasn't been mentioned look up latching relays, much nicer than contactors for this sort of thing.
Latching relays Hager
Mainly that they don't have to sit there energized for hours on end, a pulse will change there state. Plus multiple switching is easier, just put all push switches in parallel on one pair, any switch closes the control circuit momentarily and the relays flip state from on to off or off to on.
How many people are putting in lighting circuits >10A anyway?
Reply to Lighting contactors in the UK Electrical Forum area at ElectriciansForums.net
