R
Richard3009
When installing loads of lights in a warehouse, is it common practice to use lighting contactors driven from a standard light switch, what would a typical installation on a large scale consist of.
Discuss Lighting contactors in the UK Electrical Forum area at ElectriciansForums.net
Me for one, I have to put in lighting feeds of up to 400A three phase sometimes
I have used impulse/latching relays in lighting control in the past, but usually when replacing an existing system with momentary push button control or if for some reason momentary push button control is required.
I suppose they are an all in one package for easy install and ready to use and as you say simple switching operation but personally I'd design my own using a PLC switching the contactors and thus can add my own computer interface set-up and timing options, even fit a touch pad screen for greater control and dimming options.
I've only bothered doing the PLC set-up once and came in at half the material cost that of a smart lighting control kit on the market ...customer was happy as larry, I used 3 position center off spring return switches - push at bottom for full lighting, push repeatedly at top for number of rows you required lit, rather simple program and even set auto timer function and Holiday timer in it, no staff interaction needed. A few yrs later the customer asked me if it could be changed so got the requirements told him to plug it in online and I sent new program within 30mins of request ...he couldn't believe I was able to just change it all without even visiting site....One happy customer and it was invoiced as a callout... now lets see anyone achieve that will pulsed relays and modular timers etc
Not trying to knock the pulsed lighting relays they are a ready to use easy to install set-up most sparks should be able to follow although Ive seen a few struggle even with these :O
Fine, for industrial setup, I have done a packhouse previously with over 40 fluorescent fittings controlled by these, obviously the switches operated a few of them all together. How many people are putting in lighting circuits >10A anyway?
using a D type mcb will allow a greater inrush, adding in some time delayed relays/contactors into the mix wouldn't hurt on larger installs either.[/COLOR]Yes missed that TONY! .... Its a world away from small scale installs .....
How many people are putting in lighting circuits >10A anyway?....
Supermarkets.
Large warehouses
Shopping complexes
Big factories
TBH the list goes on ... this is that difference between small jobs and MOHASSIVE ones, most sparks never even have to design a large scale lighting install never mind been competent to (you don't get taught to nowadays)
No disrespect but when you post how many sparks are putting in lighting circuits over 10amps it shows your limited experience across the electrical industry ... design your thoughts on the OP's question ..be interesting to see how you do it.
Why aren't you using LED's they pay for themselves in energy savings, lower rated infrastructure and maintenance / whole cost of replacement . Crazy not to use LED's in today's world
Well to anser the hypothetical question "what would a typical installation on a large scale consist of."
It would be LED's today so the loads are completely different from what's been discussed...
Typical sales pitch ... they are Energy efficient but the light spectrum does not suit every industry, also because the LED industry is still in it infancy very few are giving a life that is printed on the tin, its a very large upfront cost that most cannot afford and can take several years to see a return.
Ive fitted LED solutions on several occasions and TBH in industrial they are hit and miss as complaints come in thick and fast regardless of Lux readings been the same if not better than the metal Halides they replaced.
I even had a scheme design by the rep's of the supplier and we did a 3 yr run on a area and at present for a fitting giving expected life of 50,000 hrs all have failed (12 fittings) except one in under 30% of their stated lifespan... we are currently in legal procedures with the suppliers, this is not a back alley company but a well known market leader but as its still in legal grounds I not name and shame.
The LED market is still maturing and so many jumped on the bandwagon it got saturated with cheap crap retailing at high prices and regardless of the actual LED's been good for 20-50 thousand hrs it was the electronics that failed frequently.
Would you buy something claiming 50,000 hrs with no more than a 3 yr cover ..... No! ....some off the leading quality ones now give 10yrs cover so show me a high bay with that cover and Ill consider it!
Reply to Lighting contactors in the UK Electrical Forum area at ElectriciansForums.net
