kWh = Power (in kilowatts) x time (in hours)
You do the rest...
Now that rings a bell, thanks! So (and this is from memory so I may very well not be getting this right) if E=Pxt then because I've already got the watts per hour then the math for the tumble dryer is...
E=Pxt
1.4kWh=1400x1
A=w/v
5.8A=1400/240
So then a 6A fuse should take that load. Obviously I have other loads to add to that in this situation BUT from what you guys are saying that seems very low? And now I've just seen the manafactorys details which prove my math to be wrong. Bugger this, I give in and will now just google the details.
I'm doubting my math now. To work out the amps when all I've got is the annual consumption I take the annual and divide by 365 (days) then by 24 (hours). This then gives me my watts per hour, I can then add up each appliance and divide by voltage to give me my total amps to find my breaker size?
what are you drinking tonight?
E=Pxt
1.4kWh=1400x1
A=w/v
5.8A=1400/240
230 is the voltage used in calculations.
In them situations just go to manufacturers website 1 min and bam 10amp for dryer rest will be just as easy to find.
Lighting spur off a fuse spur
Mr. Anderson,
telectrix,
