like for like shower | on ElectriciansForums
Discuss like for like shower in the Australia area at ElectriciansForums.net
P
Peter Woodford
guys
if your replacing a like for like shower if its not rcd protected does this have to be done as well
guys
Long after the event i know, but only found your question on a search. Answer is from HERE
EDQ10
If I replace an existing electric shower, do I now have to provide RCD protection for it?
EDA10
No, unless RCD protection is required by the manufacturer’s installation instructions, or a new circuit is required (to provide for increased load, for example).​
134.1.1 510.2
According to their website / installation instructions, in Credas' website they don't mention RCD's but Tritions' do recommend the use use of a 30ma RCD.
Quote
A 30mA residual current device (RCD) must
be installed in all UK electric and pumped
shower circuits. This may be part of the
consumer unit or a separate unit.
EDQ10
EDA10
134.1.1 510.2
I have to admit even if the manufacturers did not advise fitting a RCD I think as it's a shower it is the few times I would go against the guidance of the Regs and fit one.
Know if you have the proper disconnection time on a fuse or MCB it would be safe ....................but do like that additional protection of 30mA and 0.04 secs
It must be a shower that has been on the shelf for a while, or an import. All the main stream showers that I have fitted for the last year or 3 have all stated must have a RCD, or that it must be installed in accordance with BS7671 wiring regulations in which case it must have a RCD anyway.
Cheers......Howard
Even if it is a like for like, it can go on a minor works cert but will still need notifing as it's a special location
Like for like replacements are not notifiable, even if carried out in a special locations, unless it is a consumer unit.
Have a read of the IEE's electrician's guide to the building regs,parts b and c on page 22.
Reply to like for like shower in the Australia area at ElectriciansForums.net
M
Tiling on Universal Shower Bases Hi there - I’m hoping to get some advice. I’m a builder, based in Melbourne, Australia. I’ve recently done a...
Melbourne Builder
M
J
Traymate Shower tray Hi guys, This is my first post so apologies if this isn't the right section for the post. I'm a qualified plumbing and...
Jeefa
J
