Link Light Connector/Plugs | on ElectriciansForums
Discuss Link Light Connector/Plugs in the Electrical Tools and Products area at ElectriciansForums.net
Amp David
Mentor
Glossop
Does anyone know if its at all possible to get the plugs that usually come moulded onto mini link light cables on there own.
I need to wire some up using 2 core flex but the leads you get arn't long enough so was thinking of making uop my own cables.
Cheers
I had this problem once. Ended up cutting the plugs off and extending the cable with flex, cripmed and heat shrinked in white, stagger the crimps instead of putting them side by side looked OK but was hidden behind the unit pelmet anyway. These plugs are like rocking horse doodah to get hold of.
Places selling linklights usually sell other lengths of lead for using with them.
Leads are not always interchangable between different makes.
Given up on the manufactured leads, as I need one thats 1.9M and cant find one local. Got the 2 pole connectors now, with a length of flex, top job.
Reply to Link Light Connector/Plugs in the Electrical Tools and Products area at ElectriciansForums.net
It is possible that the particular socket you normally use in the kitchen is worn, or there's a wiring issue behind, contributing to the heating...
Hello - Did you get your problem sorted?
