Liquid plastic (interested that's all) | Page 2 | on ElectriciansForums
Discuss Liquid plastic (interested that's all) in the Electrical Tools and Products area at ElectriciansForums.net
Any customers who are metal workers? Maybe see if you could a new piece turned out of steel to replace the broken plastic moulding? If you could get the profile right, cut a slot down it to insert the cable.
We get something called copper reducing links which are basically a reducing ferrule and would work to replace that broken plastic part. I can't find a UK supplier though. You'd need to heat up the nipple and pull it off first then refit it using a solder pot afterwards. It's a lot of messing around to save a few quid though Tel.
**edit** Here's something similar Copper Round Pin Terminals - Cablecraft - http://www.cablecraft.co.uk/copper-pin-terminals.html
You could maybe try slotting one with a dremmel tool rather than removing the nipple.
Reply to Liquid plastic (interested that's all) in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
