Little Wiring Brain Teaser | on ElectriciansForums
Discuss Little Wiring Brain Teaser in the Electrical Course Trainees Only area at ElectriciansForums.net
SparkyChick
Supporter
South Wales
This is nothing spectacular, just a little question to get your wiring grey matter whirring :)
Setup is as follows:-
Hall - 6 cables:- Loop in (T+E), Loop out (T+E), Supply to outdoor light (T+E), Supply to hall light (T+E) and two 3 core and earth cables to landing
Landing - 3 cables:- two 3 core and earth cables to hall, Supply to landing light (T+E)
Your task if you fancy giving it a go is to draw a wiring diagram for this setup such that the hall and landing lights can be switched from both places, and the outside light can be switched from the hall. Specify the switches to be used in each location and show the connections at each location.
When you post your pictures, please be sure to put them in a Spoiler section (See the insert menu - the ellipsis button on the right of the smileys) so other people can choose to look at your solution or not.
[ElectriciansForums.net] Little Wiring Brain Teaser
Ok i'm on holiday & im still checking this forum lol
Here's my attempt using Microsoft Paint
Not a bad effort and for a slightly different question it would be the perfect answer... but read the cable purposes again carefully. The cables in the OP are the only ones involved.
[automerge]1569696958[/automerge]
In fact, I think @Loki it's my fault. I've just re-read my OP... I should have made it clear that the cables I've listed are all at the switches.
I tried the ‘spoiler alert’ thingy. However I think a few too many drinkies affected the process ?
Ok so I've redone it again this time switch fed :)
Better, but you've cheated :) There is no loop at the landing switch. I'm evil like that (actually just didn't want to run a loop into the landing switch) :D
However, unless I'm much mistaken, your two way switching won't work in this version. For the general case (the hall light) you had it spot on in your first attempt.
Hi SparkyChick,
I know it could be wired like
When i was on new builds I'm sure we wired it like i drew it. Im always happy to learn from my mistakes & ive made a few :eek:
I've just tried following the path through the circuit & it looked ok but i could be wrong. Ideally my landing light should be on left side of 2 gang switch.
Ive made sure that upstairs light is fed from upstairs circuit & hall light is fed from downstairs circuit.
Hi SparkyChick,
So this diagram is basically the solution to the landing light. I elected not to feed the landing from the upstairs lights for two reasons:- 1) I've done it before and I'm not keen on the fact you have to isolate two circuits to fully isolate the two switches and 2) because in this instance I didn't want to touch the upstairs lighting circuit (it's a full rewire except that one circuit - accessing it is difficult without significant damage to the building fabric and it tests OK).
I could be wrong with my statement about the two way in your second version not working, but I drew it out and I can't see how it works.
Thanks to anyone that had a punt :)
To my trainee... you know who you are... get your bloody finger out... I'm still waiting for a van chat on your attempt at this :D
  • [ElectriciansForums.net] Little Wiring Brain Teaser
Reply to Little Wiring Brain Teaser in the Electrical Course Trainees Only area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
