I go to a job today, a nice simple one to replace a light switch.
They have a nice 8 way board with 6 used ways, all RCBO's installed about 2 years ago. So i turn the light on that this switch controls and turn the relavent braker off and out goes the light. I then pop on my volt stick as i usually do before i check for dead and it beeps. Odd i think. So just to be sure i turn all the brakers of and the volt stick still beeps. I turn off the main switch and volt stick no longer beeps. To double check this i set my tester to volts and run through the same procedure again. Sure enough, there is a voltage at the switch until i turn the main switch off. So i think the sparky who installed the CU has made a big mistake and somehow connected live neutral reverse. So i pop the cu cover off and all looks ok (correct coloured wires in the right postions), the incoming tails look ok (the correct coloured tail in the correct terminals). I test for polarity with my AVI, and the live and neutral are reversed. So i mention to the client that this isnt good and he informs me that the meter was changed 3 months ago. I follow the live from the head and sure enough it goes into the neutral of the meter. Unbelievable, i mean these are supposed to be professionals and it isnt hard to test polarity.
So i phone the DNO and they tell me that it isnt their responsibility as they only go as far as the head and its the billing companies responsibility. So I leave telling the customer to contact their billing company ASAP to get them to sort it.
I am still fuming about this, i cant believe they screwed this up so bad!!!!! Not to mention it very dangerous!!!!!!
