Live wire taped off in the loft. | Page 2 | on ElectriciansForums
Discuss Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
Goatus
Glos
Afternoon all, new on here and hoping someone maybe able to offer a bit of advice?
I am flooring the loft at the moment in the loft, and there is a length of wire (grey 3 core) that has just been taped off and taped to the rafters. The wire is live (240v) but isolating the MCB for upstairs lights/sockets and downstairs lights sockets makes no difference so assuming it's not to do with them! I did wonder whether it was put up to faciliate loft lighting?
As mentioned it's a fairly new build house.
I'm a novice at this and am curious as to what it was and if anybody would know?
Many thanks
Nick
Ok thanks, I did try isolating the sockets upstairs but seemed to make no difference. I shall investigate some more when time permits. I think that'll probably be the best option to get it terminated properly , or if I find it's use it may actually be of use someway!
And the washing machine was a tongue in cheek reply to an earlier post :thumbsup:
Thanks again all!
As it is a fairly new build I would be informing the builders of the dangerous condition that the building has been left in. I wonder how many other properties have the same in the loft?
Thanks again all!
You're right Goatus, that cable looks long enough to terminate anywhere you like, depending on where it's fed from will determine how many sockets yo can have, may be possible to have lighting as well, only a competent Electrician will be able to help, don't try it on your own please, get professional help, the jobs half done anyway getting the supply to the roof space, don't waste the opportunity.
[ElectriciansForums.net] Live wire taped off in the loft.
Is that @buzzlightyear s full name Pete?
It’s rather posh!
I prefer Buzz an air of mystery, just what this forum needs the Buzz files, sounds OK ? if it was televised who would play Buzz? Dominic Cumberbatch would be my choice, ugly yet strangely mysterious, bit like Me. But Buzz sounds better than Pete don't you think? Think I'll change my name to be Mysterious, something like the pedanterous, or maybe Toolman. several other names I could think of but I would get a ban if I typed them.
Reply to Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Hi All, Looking for some advice into my build. What I've basically done is add additional RCD protection to my 100% off-grid 12V 3300W Inverter...
