Live wire taped off in the loft. | Page 3 | on ElectriciansForums
Discuss Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
Goatus
Glos
Afternoon all, new on here and hoping someone maybe able to offer a bit of advice?
I am flooring the loft at the moment in the loft, and there is a length of wire (grey 3 core) that has just been taped off and taped to the rafters. The wire is live (240v) but isolating the MCB for upstairs lights/sockets and downstairs lights sockets makes no difference so assuming it's not to do with them! I did wonder whether it was put up to faciliate loft lighting?
As mentioned it's a fairly new build house.
I'm a novice at this and am curious as to what it was and if anybody would know?
Many thanks
Nick
You could try by turning every mcb off, then turn them on one by one while checking the cable until it becomes live again, then you’ll know which mcb it’s connected to.
Could well be a supply for a loft socket that whoever first bought the house didn't want to pay extra for, so was never fitted. Either a spur off somewhere (if live), or not actually terminated in the consumer unit (if not actually live, just picking up stray voltage due to proximity to other live cables).
If its a new house it could have been put up there for future use. How did you test it was live.
Recently did a wetroom in a new house, had a mixer shower switching to an electric shower. Found a 10mm in the board taped up with the other end in the loft ready. Had a semi all day after finding that, saved half a days work.
What a semi detached?
Aerial! Gees.
All these jokes are Cillet Bang out of order.
Daz n’t say much for the experts suggestions here.
Persil.... persil?.... no can’t think.
Give it time, I might have a Flash of inspiration.
OP. For the sake of safety, isolate all power in the house, check the cable is dead and terminate it properly in a secured joint box.
Then you can finish flooring the attic and worry about getting a spark to check it another time
Aerial! Gees.
well, this post has certainly wiped the floor.
What size cable?
I’ve come across a live cable taped up yesterday while in a loft. It was the old shower feed.
Can never understand why people don’t just diconnevt the live conductor in the dB/fuse box rather than just being lazy.
And the neutral, if the circuit is RCD protected (which, in most domestic circumstances, it’s going to be nowadays).
Reply to Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Hi All, Looking for some advice into my build. What I've basically done is add additional RCD protection to my 100% off-grid 12V 3300W Inverter...
