sparkatus12
Just been to neighbours house because he said cooker was not working. Turns out the fan oven was fed via a fused spur of what appeared to be the kitchen ring. However couldn't get continuity between feeds so is a radial on 32A breaker or spur feeding spur. (neutral on load side of spur had melted but fuse hadn't blown). Decided to check next spur and found out it was doing the hob. However this one is fed from the house ring. Once again neutral melted but fuse not blown and also no continuity again. A kitchen fitter done it all about a year ago and also added other sockets and a shower apparently. Just wondered if you guys had an idea why the neutrals had melted but fuse not blown. (strange to have 2 spurs with loose connections on the load neutral). Going to test the whole house at the weekend. Thanks.
