C
Chris sparky
Good evening guys and girls.
A friend of mine has had a log burner recently installed in his home. Other than just heating his lounge it is also going to do the hot water. For this reason there is a pump located behind it which obviously needs power. To get to the pump the cable would have to be clipped to a wall behind the heater. There is a gap of about 8-10 inches between the heater and the wall. Just wondering what your thoughts would be on cable type to get to the pump. Would you use a heat resistant flex or FP or other?
Not sure what the temp will be behind the burner. Will have to ring the manufacturer to find out.
Cheers
Cheers
