Long cable rods | on ElectriciansForums
Discuss Long cable rods in the Electrical Tools and Products area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
We might need to pull a cable through around 100m of fairly wide duct (around 10cm) and it might not have an existing draw rope. It has a 28mm water pipe and CAT-5 network cable in there, so one option might be to use the cable as a sacrificial means of pulling a rope and another cable through with the rest, but ideally a cable rod set/reel would be better that can go to around 110m.
Any suggestions for this, or a better way?
There's no way you'll be able to push cable rods 110 meters.... We managed to push some black class 10 Hdpe water pipe that came on a roll over 100meters but we had to unroll it nice and straight and leave it in the blazing sun to get the curves out of it before it worked.
I'd just use the CAT5e cable as a drawrope and pull a new one through with your new cable and rejoin it using your favourite IP66 joint system.
Ideally there should be inspection chambers at I think a maximum of 50m apart, I have done 80m with mine down 150mm smooth duct before where no draw tape was installed.
Other method is plastic bag with string attached, then Hoover/ garden vac to suck it through. Of course only works if the duct isn't swamped!
100 meters is quite along length without any inspection/boxes in between. You could try big Rods as for the cut and draw on the cat5 make sure you have good movement and it easy to pull because if you hit a blockage and cant get it back you've lost it. Good luck
Thanks for the ideas. Sacrificing the network cable is probably cheaper than getting long enough rods, etc, so that will likely be my first attempt. Ironically it is to put in more networking (but this time fibre optics)!
You can hire a cobra, as used by the utility companies, relatively cheaply.
Ah, didn't think you could hire that. I did find the company who makes them but have not asked the price (yet) but given how infrequently I need this, hire makes a lot more sense if the existing cable proves a failure.
Reply to Long cable rods in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, Just wanted a bit of advice in regards to a small installation of emergency lighting. I have a fairly long warehouse that needs some...
Electrical2Go - Save Time Installing Cables with Super Rod At Electrical2Go, we're constantly striving to bring you the latest and most...
