We might need to pull a cable through around 100m of fairly wide duct (around 10cm) and it might not have an existing draw rope. It has a 28mm water pipe and CAT-5 network cable in there, so one option might be to use the cable as a sacrificial means of pulling a rope and another cable through with the rest, but ideally a cable rod set/reel would be better that can go to around 110m.
Any suggestions for this, or a better way?
