Long SDS plus drill bits | on ElectriciansForums
Discuss Long SDS plus drill bits in the Electrical Tools and Products area at ElectriciansForums.net
K
keith915
Just a quickie guys. Looking to buy a threesome of 1000mm or 1200mm masonry bits. Any recommendations? Erbauer/Titan are possibilities but open to spending more on better quality bits.
one word of warning. never attempt to start a hole with one of these. they can suddenly bend at 90degrees and rip your face off. always start hole with say a 16" bit then shove the long one in.
I wanted a 1000mm x 20mm the week before last and was buying it as a single for ÂŁ 19
Spotted the same make 3 different sizes in a pack under the display unit for ÂŁ 20
bought one of those sets 14.99 and it was cracking , drilled a few holes through stone at a castle with the 20 mm if i needed a larger hole i went through again with the 25 mm it lasted ages , if fact the last time i used the 20 mm i was drilling a 2 ft wall and half the end snapped so a went out and got a new audax 1 meter 20mm ÂŁ87 + VAT , it drill 12" and burnt out , so i finished the hole with my good old faithfull half tipped drill bit , and got a refund for the expensive one !
Seems a split decision between cheap and expensive!
Struggling to find some Irwin sets but I've found some silverline ones which I'll try out. ÂŁ13 is the cheapest I've found for the 1000mm, ÂŁ29 for 1500mm sets so will see how they go.
Reply to Long SDS plus drill bits in the Electrical Tools and Products area at ElectriciansForums.net
how often will you need to use it? Would renting one from a tool hire place be more cost effictive... and might give you an idea of good brands...
