Looking advice on fixing laserlevel battery | on ElectriciansForums
Discuss Looking advice on fixing laserlevel battery in the UK Electrical Forum area at ElectriciansForums.net
Class2020
Eire
Hello, first time poster. I am here looking advice on how to connect my batteries in my laser level. I dropped it and it stopped working. Opened it up and the attachments to each battery have broken. I tried to.solder it but it doesn't seem to have taken to it..any tips or advice on how to join these.
[ElectriciansForums.net] Looking advice on fixing laserlevel battery
Probably a bad idea but I usually file/sand the surfaces to be soldered to remove the plating, add a dab of flux then quickly solder with a high power iron. If the drop was enough to cause damage like that the alignment/calibration will need checking.
when you say a high power iron, how high. Ive one out of lidl. im thinking it might not be strong enough
Reply to Looking advice on fixing laserlevel battery in the UK Electrical Forum area at ElectriciansForums.net
You need a galvanic isolator in the earth coming from the shore power. If using lithium batteries you will probably need a dc-dc charger to...
davesparks
I was suspicious that your MH-CD42 was not producing sufficient voltage under load for the PWM controller. If you have a multimeter you could...
