Looking for suggestions to buy cordless drills (for contractors)? | Page 2 | on ElectriciansForums
Discuss Looking for suggestions to buy cordless drills (for contractors)? in the Electrical Tools and Products area at ElectriciansForums.net
I have bought used and dispensed with most major brands. A friend of mine bought the hilti option, within weeks found that they were not up to the job. A cost ananlysis of hilti and other less expensive drills leads me to incline toward less expensive as in the long run it is cheaper to replace cheaper drills that last as long as pretty well any drill. Brushless and 5 AH are the way to go. What do you want in a drill. So in my view a drill that can last all day battery wise and not burn out. My best drill so far is the milwaukee set. I think most drill makers now do interchangeable bodies/batteries so that you can get 3/4 batteries to use on all your tools. i.e. circular saw, angle grinder, jig saw and drill hammer and impact. Impact is a must although noisy in offices and tends to annoy the tenants. Hikoki drills seemed to always fail on the chuck for some reason I replace the chuck 3 times and stopped with that drill. De Walt seemed to not like my work routine which consisted of maybe 200 plug and screw operations on long runs of conduit in offices. Some do smaller drills. They have cut the body weight down which is also good if you are doing lots of drilling as we do. I normally have at least four drills on site hammer/impact. Of course there is always a battery on charge ready to continue the good work. So decent AH batteries is required for hard work. As I say so far the milwaukee have shown they are good drills for hard work and show no signs of packing up yet.
Nice to have someone here as experienced as you. yes, hilti is expensive but the cost is not a big factor to me but as you have already told cheaper options do their job pretty well, i will have one of them for sure.
Thinking about buying batteries with fuel gauges or smart chargers to extend battery life
Hi,the choice of cordless anything,is always down to several factors...cost,use,personal choice,and yes,even fashion.
There is also a big trend on most youtube tutorials,for doing everything,with a battery tool...you see chopsaws,table saws with big double battery packs....and a socket outlet,2 meters behind it ? - always choose the appropriate tool,for the job.
I can rate the Hikoki,,Milwaukee and Hilti gear,probably putting Hilti in the lead for engineered quality,but not on every tool they make.
Pick the tool for you and your job...i went to visit a pal who was doing a load of electrical/coms work in an office,and he had invested heavily in Milwaukee kit....to "obviate extension leads everywhere..." he still had the leads,as his lads still needed heat guns and battery chargers,so...
And lastly,ignoring theft and abuse,buying quality gear,is always the best policy. I have an old Hilti 14v combi,which i keep,as it has 3 speeds,Hi being 2400rpm,perfect for burrs,mini-wheels,small bits,etc.
It can still do a 20mm hole through 1" steel plate,with a Starrett holesaw,on a single 3.3Ah battery,
Hilti...My uncle had one in the past, can't remember the exact model
Fan of Bosch blue myself. Never had a motor failure, however hot I've run them. unlike the Dewalt I had for a short while. All my batteries are going strong, right from the ones that came with my first drill 10+ years ago, although one did die, and then come back to life again.
Latest batteries have a 'fuel gauge' on them.
As a contractor, what sort of things you generally look for in a cordless drill? What will be the factors to pick the cordless drill in this case? which brand will be most reliable? Would greatly appreciate any advice from you guys…Thanks
I stick with what i know, full tool set is makita bar a jigsaw and they have never failed me. tried a double battery SDS last week was like a kid at xmas!
Personally think all the big brands are much of a muchness.
My apprentice killed his new makita in a few weeks. My Dewalt combi is 2.5 years old with no problems so far. The previous ones lasted 2/3 years of daily heavy use. My Dewalt impact driver is 7 years old and going strong.
I expect similar stories for all the big brands. Sometimes you get lucky with a tool, sometimes not. Buy something with a good warranty and top of the brands range is my advice.
I got some nice jobs round Gretas,due to the fact, that when i quoted,i showed her me compact wind turbine powered battery charger.
We had to open all the windows,to keep the 12 Ah batteries up to speed,and she had to put more coal on her fire,so i'm not doing anymore work,for her ? ....it's all blAh blAh blAh (see what i did...)
18v is the standard now, I don’t think going to 20 will make much difference.
In fact in some cases going even higher makes no difference. I have just bought the Bosch 36 volt "professional". Its a replacement for its long serving 24 volt cousin that has done seriously hard graft over 20 years. I find the 36 volt inferior in every respect to its predecessor
I have Blue , battery and mains >Used the mains today to put a 12 x 900mm through a very old basement wall. brand new SDS bit. Piece of cake !
Depends how many batteries you have acquired over the years.
I have seven 18V Bosch batteries in full working order, so my last purchase, a 115mm grinder, was just the bare tool.
Rarely buy tools any other way - in fact the last time I bought a tool with batteries was because it was cheaper than buying batteries separately - the tool was sold on ebay to further reduce costs.
Another Bosch Blue man here, been using them forever , they haven't given much trouble but are a little pricey
Starting out again I'd be looking at other brands like DeWalt and Milwaukee for comparison.I think they're big names in the US according to home depot when i was looking
Reply to Looking for suggestions to buy cordless drills (for contractors)? in the Electrical Tools and Products area at ElectriciansForums.net
C
Looking for Guidance on Where to Start! Hello, I am new to this forum community and very excited to get involved ! I am looking forward to...
catherinebennett
C
An example of the long term race to the bottom of quality of work in our industry, IMHO.
