LOT20 - just thought id start a rant | Page 2 | on ElectriciansForums
Discuss LOT20 - just thought id start a rant in the UK Electrical Forum area at ElectriciansForums.net
It doesn't sound much different to making a car with the steering wheel on the other side so they can sell it to a different market, or selling electrical appliances with a voltage switch (which is often just for show).
I heard a report that there were plans to reintroduce the sale of champagne in pint sized bottles, which the French are more than happy to produce exclusively for the UK market.
If producing more than one variant to open up new markets is financially viable, I don't see why manufacturers would not want to.
Anyone think the EU come up with these, to be quite frank, daft ideas, just to keep themselves busy ............
Cut back spending on science , then make DUMB scientific decisions .
...Good saving to be had with modern refrigeration ..
( heat recovery -may work ...so long as sewers don't
run too cool !)
Do we have no real engineers ?
LOT 20
That means for us that the heaters we make have to have an electronic switch rather than a mechanical switch, a 2kw heater is still a 2kw heater.
It also means that for one particular range we no longer sell wall brackets with it. It now only comes with feet. This makes it a portable appliance and LOT 20 doesn't apply.
Get switched on to LOT 20 | Dimplex - https://www.dimplex.co.uk/news/get-switched-lot-20
We also spent hundreds of thousands to change tooling and testing to conform with this.
better off standing in an audi. that way your legs are ready to walk when it breaks down.
A mechanic pal of mine once told me in regards to VAG (VW AUDI GROUP) “VW / Audi ain’t what they used to be. Seems when they took on Skoda, Skoda learned a lot from VW, but also VW learned a lot from Skoda!”
There is truth in that . To be fair the older Skodas' were better than the newer ones .
I have said this before; my mate has a fleet of Skoda Taxis from around 03 to present day. One of them was taken out of service just short of one million miles on the clock : Not because it was worn out , but because of it's age. It was sold on to one of the lads cheap, and is still running on the same engine to this date. They were all meticulously serviced and maintained. Most of them have over 3 hundred thousand miles on them , some over five hundred thousand.
The newer replacements are causing problems with nowhere near these mileages . Good business for one and not the other?
The newer Audis' are a more common sight in the workshop too; along with the Merc's
LOT20... what a bloody P**S take..
used to fit a certain heater for customers and wall mount it, the heater came with feet and wall brackets attached to bottom.
Now due to LOT20 they no longer include the brackets on the bottom and its no longer suitable for wall mounting... have to use the feet only..
Except it is exactly the same model, same thermostat controls etc.. same power output and usage... only difference is the lack of little metal brackets....
But being a lot20 model they charge an extra £6.99!!
As i said a P**S take! i have acquired my own source of suitable brackets though :D
We sell the brackets separately :)
There's a stigma attached to driving an Audi; if you drive an Audi that makes you 'an Audi driver' - the new 'BMW driver'.
I've never owned or even driven an Audi, but I have driven past a lot of Audis which have broken down at the side of the road. Also either the indicators are extremely unreliable or the 'type of people' who drive them don't seem to think they need to bother indicating.
This sounds like the idea behind chopping plugs off appliances and wiring them into FCUs so you don't have to bother PAT testing them because "the P is for Portable".
Makes me smile. Over the last 10 yrs I've had BMW, then Audi and now a Skoda to try and keep out of this "busted blinkers" set, and of course to save up for the Ferrari van :) .
Reply to LOT20 - just thought id start a rant in the UK Electrical Forum area at ElectriciansForums.net
I guess my last post was even less direct than intended.
nicebutdim
N
Yea its exactly that, its a photographed print out, the landlord is 85 😂 he is expecting 2 visits i was just trying to save myself the time, the...
suffolkspark
