O
Octopus
Cheers Murdoch, my sparky has tested from the earth bond under the sink in kitchen back to CU and it was fine with wander lead and megger
So not at the areas you are concerned about then ..
Discuss Low Earth Voltage in bathroom from bonded fittings in the DIY Electrical Advice area at ElectriciansForums.net
That would be TN-C-S - not TN-S.my sparky says Im TNS. I'm told that the setup will be that the earth is taken from the Neutral
Thanks so far for the interest,
Midwest I don't want to bond the shower frame - I'm using it as a 0v to measure the others in the absence of 100m of earth cable and a spade in the garden - I appreciate this is haphazard but I can feel a tingle from the showerhose and sometimes the rad too, never anything from the shower frame.
I appreciate your sentiment though Midwest - I'm just seeing what i can do on the home owner front while I'm waiting.
KrisI've had two Part P registered sparkies round already and booked in for next week hopefully to do some more testing. Unfortunately it's not something I can instantly achieve - seems to be a busy time round here - there is a massive amount of housing being built so I'm just waiting in line - I appreciate your sentiment though Midwest - I'm just seeing what i can do on the home owner front while I'm waiting.
Reply to Low Earth Voltage in bathroom from bonded fittings in the DIY Electrical Advice area at ElectriciansForums.net
