Low insulation reading | Page 3 | on ElectriciansForums
Discuss Low insulation reading in the UK Electrical Forum area at ElectriciansForums.net
SW. London
Testing a ring earlier and found 0.8M ohm at 250v between (L&N) - E.
This wouldnt be a neon causing this would it as im testing between L N (joined) to E ? I have not yet tested between the three individually.
This low reading is making me hope somethings still connected, there is a digital boiler controller that I suspect is wired into the supply side of a FCU but maybe its not; would this cause a low reading like this ? or anything else to bring back 0.8M ! I tested between (L&N) - E. Thanks all
Old house?
Squeaky floorboards?
Have someone step on the squeaks while you are testing. If your reading fluctuates, you’ve got a nailed cable.
Could be a squashed cable behind a socket? Live nicked against screw?
Time consuming, but got to be done.
And if all else fails, CCTV supplied from lighting circuit ;)
PMSL !!!
Bob, you should talk, I just got 6 informatives off you :) .
There is something strange happening software wise on the Forum just now. I type a sentance and 10 seconds later I see the keystroke repeated and later still something appears on the screen. By then who knows what random rubbish I've typed :) .
Reply to Low insulation reading in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
