Low voltage from live to earth, on a ring final. | on ElectriciansForums
Discuss Low voltage from live to earth, on a ring final. in the UK Electrical Forum area at ElectriciansForums.net
Why do I only get 50v from live and earth, I’m getting 240 from live to neutral. The circuit is a ring.
The earth is not connected to anything is one of the most likely (and dangerous) reasons.
Do you know what the earthing system of the property is?
A picture of the meter and its associated wiring would be really usefull.
Edit:
Also note that I can think of a couple of other ways this could happen but the most important thing about all of them is they all have the potential to be very DANGEROUS
Please get someone qualified to investigate as soon as possible.
Edit:
It’s a TN-C-S, its only on that circuit, the other circuits are ok
Reply to Low voltage from live to earth, on a ring final. in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Found the cause of the tripping…. Just jointed them through… all clear now. Removed the smoke detectors completely. They were due to be...
