Magnetic door holders | Page 2 | on ElectriciansForums
Discuss Magnetic door holders in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
How do these work in conjunction with fire alarm.
id say they just go through normally closed contactor and when fire alarm goes off it activates contactor coil . am I correct
If you are still on Supermarkets,
The door release signal drops out the relay mounted local to the Fire/smoke doors to close them.
The same signal Opens the shop front auto doors.
And where used, releases the Maglocks on external Fire escape doors and roof access doors
And opens the Radfords barriers(gates) and shuts down AHU 1, 2, 3, etc.
Smoke vents too or are they operated manually.
Depends, Generally all circulating air fans will be shut down on a fire alarm (except fire escape stairways, that need to be kept pressurized) Smoke extraction exhaust fans would normally be under the control of the attending senior fire officer, normally from a strategically located firemans control panel!!.....
If the control is next to the fire panel, you will find the relays or contactors will have 24v coils, so the aux 24v on the panel will be passed through fire relay to you control relays
[ElectriciansForums.net] Magnetic door holders
Reply to Magnetic door holders in the UK Electrical Forum area at ElectriciansForums.net
red is the preferred colour. however white is recognised as an alternative. I would think about it and decide that any piece of cable or...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
Recommended Sponsor News
Hi everyone,
