Magnetic door holders | Page 3 | on ElectriciansForums
Discuss Magnetic door holders in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
How do these work in conjunction with fire alarm.
id say they just go through normally closed contactor and when fire alarm goes off it activates contactor coil . am I correct
Loop in and out are the fire alarm loop, and the resistor is for input signal....so forget abaut them...they have used the COM and N/C, so there is either 24v powered on to the contactor as per my diagram or they are switching 24v from psu or straight 230v keeping the contactor on in normal use and switch off in fire event.....you need to do some investigating here trace where the cable is going from the COM and N/C terminals
Few things to note, relay will only activate in fire condition, using evacuation button on panel will not activate relays. The contactor looks like a 3 pole, and i think the 400v is max contact rating at 25A. The coil is most likely to be 240v
With not seeing the site it is difficult....but can only think this is how its wired to deactivate contactor, and with using 3 poles, would think is controlling other doors or shutdowns
[ElectriciansForums.net] Magnetic door holders
Reply to Magnetic door holders in the UK Electrical Forum area at ElectriciansForums.net
red is the preferred colour. however white is recognised as an alternative. I would think about it and decide that any piece of cable or...
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
Recommended Sponsor News
Hi everyone,
