Main bond to rubber incoming water pipe. | Page 2 | on ElectriciansForums
Discuss Main bond to rubber incoming water pipe. in the UK Electrical Forum area at ElectriciansForums.net
cmgeo
Cambs
Had DB changed a couple of years back in my house that I was renting that I now live in. I was out of the country at the time. No certs were handed over and I am unable to get in contact with the guy that my parents got to do the work. I am in the process of selling the house.
The 6mm bond to gas was changed to 10mm but the 6mm to water was left with no new 10mm installed.
As title suggests the incoming water is rubber pipe. The 6mm is terminated to the copper pipe after the stopcock.
Is this acceptable? Or should the 6mm be changed for 10mm?
I would like to get a EICR done before the sale but would this get flagged up?
rubbir wotr
[ElectriciansForums.net] Main bond to rubber incoming water pipe.
Reply to Main bond to rubber incoming water pipe. in the UK Electrical Forum area at ElectriciansForums.net
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
