MAIN EARTH BONDING domestic installation | on ElectriciansForums
Discuss MAIN EARTH BONDING domestic installation in the Domestic Electrician Forum area at ElectriciansForums.net
P
piz
Hello
When we are asked to change a CU i have been told on pme and tns the main earthing conductor is the responsibilty of the electricity board.
so if this is the case why is a 16 mm earth sold on packs of 2meter tails?,
example change board 25mm tails or 16mm if 80amp main fuse 10mm to gas and water but only sometimes 4 or 6 mm main earth do we just record this on an EIC
Cheers
I'm wondering when the thread title will be relevant to the thread
As said in post 2 - the DNO must supply a suitable earth - if they cant provide one within regs then you must supply a TT rod!
The DNO must only make an earth available (if they can) and it is your job then to ensure the cable between the termination of the DNO and the CU is upto regs
Reply to MAIN EARTH BONDING domestic installation in the Domestic Electrician Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
