OP
Geordie Spark
Your logic defeats me I'm afraid. Why should a radiator be bonded?
For the same reason a metal window frame should be bonded?? :uhoh2:
Discuss Main eath bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I really can't see the big problem here, i've already suggested that you cut a trap in the floorboard above the the bonding connection. This can be screwed back down in place, ...maybe never to be lifted again during your time at the house, ...but it's there ready and waiting if access is ever needed in the future!! lol!!
Am I missing something here, I think the OP says HIS stop tap is at the back of the house, Would it not be more sensible just to bond it after his stop tap? Rather the under the floor on the water boards (presumably) pipework?
following from somerset.....
if the only accessable point to the water mains is 10 metres away from where it enters the building well just bond it there !
f*** the 600mm rule if its a pain.
Aye, I would bond it wherever accessable, However from what I have read the OP says his stop tap and meter is at the back of the property, therefore I would say the proper place to bond would be there, as this is the start of his pipework, the bit under the floor probably is mains pipework as he says it tees of for upstairs flat.
If the OP was a spark he could decide but as he isn't maybe he should get one round to confirm what's best and install it with the new cu?
Maybe a spark could advise but this is work I can do as I want the basement area for storage I could bond there, close to the outside earth, the electric meter and the gas entry. Or I could run 15m to the rear stop cock and meter, which probably is very much further from being buried in earth. I though earth impedance might have been measured instead of having to visually inspect the condition of the pipe-cable connection. I'd be suspicious of the whole length of cable and what might have happened to it if I couldn't run a test, if I wanted be scientifically sceptical about the situation.
No offence, but I don't take the point. I'm thinking I don't need a new CU and that in any case I can save ÂŁ100 doing the bonding myself.
What I am unsure of is
(a) what earth system I have, being a big, central, road I'd expect TN-C-S. Why?
(b) how the adequacy of bonding is measured. Look it up in the latest version of BS7671
(c) why I'd bother.
Reply to Main eath bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
