Main Fuse | Page 2 | on ElectriciansForums
Discuss Main Fuse in the Australia area at ElectriciansForums.net
B
BEN5637
hey chaps, just need a bit of advice. Had a CU and PEB upgrade job today. Arrived at the job with a 10 way board to discover whoever quoted the job didnt account for the fact that a 10 way was miles too big for the space. and there was no means of isolating the installation. A disconnect/reconnect or isolating switch. rang the gaffer to explain and he said cut the seal as this is allowed in the Woking area. As anyone heard of this or is he pulling my chain, explained that to upgrade the tails I would have to cut the meter seal as well. Would rather not say who I work for but its a large company
I was always told that you could only cut seals on fuses to isolate the supply in an emergency!!!
Have cut many seals and pulled fuses to get the job done - then rang board to ask for seals to be replaced. over the past few years i have found that they dont even bother to reseal. Any electrical factors worth their salt will stock "temporary" seals. Some of them look exactly the same as the ones the boards use!
Cut away and earn your living.
did a periodic few weeks ago with the main tails being 6 mm twe next to the meters was a notice thats its a criminal offence to tamper with the equipment so as not to get into trouble with the nice power guys i rang them up and told them i was issuing a danger notification but was told it wasnt there responcablity ye right catch 22 come on were watched all the time what we do so about time they did it ,so cut the seals and changed the tails ,stupid thing was the CDU was new !! previouse house owner replaced
totaly agree all installations should be labled with whats in the fuse and have a main switch:D
I was told by an scottish power engineer inspector you can cut the seals of the fuse in an emergency but are not to touch the meter tails
i do and the reseal especially in the case as above when it can take 4 days for them to come out
oh it was a 4 bed house shower electric cooker plus loads of down lights warmest room in the house was there the CDU was lol !!!
What I do is cut the seal as near the back of the seal as possible , then once finished put a tiny dab of superglue on the cut bit to rejoin it, and rotate this join so is hidden behind the main fuse.
Dealing with EDF is like pulling teeth, so screw 'em. That's what I say :)
I’ve always been concerned over cutting seals just in case Me Meter Reader showed up just at the point the main fuse is being pulled! But after a recent visit by EDF to move a meter on a job I’ve changed my tune. Guys turned up to dig out the supply cable (As they have to dig out over a live cable) and was asked if I’d pulled the main fuse. To which I replied NO….lie,lie,lie! I was then asked to go do it….While they stood and watched! I will never not consider cutting a main fuse seal again but do draw the line to the meter one. I did read this week in Switched on magazine that it has been denied to train sparks for pulling fuses as there was insufficient response form the industry! Would be nice to be asked may be!
Just nip them up with your side cutters.
I worked for a contractor for EDF installing new connections (LV jointer) and they wouldnt give us the proper crimps - we just used side cutters/pliers.
Reply to Main Fuse in the Australia area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
