SteveT
Evening all,
i have an issue with and RCD in a Hager split load CU.
Was called because the RCD tripped and wouldn't go back on. When I got there I turned all the breakers off and tried it and it still didn't stay on. I turned the main sw off along with the breakers and it went up but off again as soon as board was energised.
Voltage is at 239v so no issue with supply plus the first have of board isn't RCD protected.
changed RCD with the same results.
No work been done or anything added, any ideas?
Cheers,
Steve.
Cheers,
Steve.
