OP
Phil
+1 for mains although fitting cheap 12v ones the customer supplies and getting call backs to fix them comes in nicely
Discuss Mains or extra-low voltage downlighters? in the Electrical Tools and Products area at ElectriciansForums.net
Hi tuckermot,
I agree I have found some problems with the transformers in that a lot are really built to a price and will not give any tolerance on how many lights can be connected to them. I know that for safety the 12 volt units are better but it can be a niggle having to go back when a transformer goes down and find out why. The fire rating point is important as a lot of heat is produced by down lighters and it is important to prevent fire. The problem is that the excess heat can reduce the life of the luminaires / lamps ( didnt say 'bulbs' as I get into trouble with the politically correct brigade).
Has anyone found that the lamps in the down lighters in kitchens can fail earlier than stated? I see a lot of claims on the life of the lamp and a lot dont ever get to last the 2000 or so hours claimed. I know it is probably an average thing but it does seem that a number do fail short of the expected life. I did wonder if it was an excess heat issue but this should have affected all the lamps the same - whoops sorry changing the subject.
Best wishes
Rex
mains....!!
no messing about with stupid 12v transformers!!
Since this thread was created in 2010 approximately 90% of the 12v fittings since then have probably failed by now :lol:
Feels weird now back then I found quick warming CFL ones to be pretty good, glad LED has shown me the (much cleaner/cooler) light
Reply to Mains or extra-low voltage downlighters? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
