maintaince free junction box | on ElectriciansForums
Discuss maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
Suffolk
Are maintaince free junction boxes safe to use under floor boards? Will one rated at 32 amps be suitable for use on a ring main? Any brands you recommend?
I exhaust all other avenues before putting maintenance free (MF) junction boxes under floorboards as, put simply, it's never going to be as good as a continuous length of cable. However, sometimes you have to.
I use wagobox http://www.wago.ltd.uk/enclosures/wagobox/ (not wagobox light as these are not MF). Plus they require a cable tie around them in the given slot to be deemed MF. Also they must only be used with correct wago terminals for the given box.
Reply to maintaince free junction box in the Electrical Tools and Products area at ElectriciansForums.net
yeah. i think so. Details here..... https://www.electriciansforums.net/threads/havent-seen-tel-for-a-month.210295/
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
