Mathematical Symbols for use in Equations
  • Thread starter Thread starter JUD
  • Start date Start date
i have the page opened as a tab and just copy/paste direct.
If you find it difficult to remember all such codes, I have got an easy way out.
Go to insert< add symbols < choose the symbol and click OK. It done. Isn’t that easy
Alt 253 = ²
Alt 167 = º
There doesn't appear to be an Alt for Ω.
The TEF forum used to automaticalliy change Ohms or ohms to Ω, I don't know if the program this forum uses would allow such.
To obtain Ω and other symbols such as ¶ or ÷ I open the 'Character Map', which I have stuck to my task bar.
Unfortunately I then have to change the font size from 4 to 2.
Some forums will automatically size the symbol to the same size as other text.
spin, how do i get this character map. the alt etc will not work on a laptop as there is not a separate numerical keypad.
marvo, what's a run box?
I could tell you it's something akin to a bash shell...but I won't :).
You should get the run box if you hit the stupid looking windows key and the letter r together.
If you have XPyou can go;
Start>Programs>Accessories>system Tools>Character Map
If you're using Vista or Win7/8 I'm not sure where they will have buried it.
The Character Map is in systom tools.
Click on 'Start', then 'All Programs', then 'Accessories', then 'Sytem Tools'.
You should then be able to right click on 'Character Map', and select pin to task bar.
