T
ted26
Does anyone know the maximum cable length that can be used for a ring circuit using 2.5 t+e with a 32amp breaker?
in a 10X10 meter square what about the drops or rises.....if the rooms got a 5 meter celing hight and your drop is from there then how big would your ring main be...
its all about cable resistance and what protection you have and the temperature and the insulation around the cable.....
if i were you id look into some cable calcs....they are a wonder to behold..
