MCB tripping help | on ElectriciansForums
Discuss MCB tripping help in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Afternoon. I have a problem on a lighting circuit where the MCB is tripping randomly. It is when just 1 of the lights on the circuit is turned on, I have changed the MCB, the switch and the light fitting, I have also done an IR test which was clear. It will trip at times of anything between 30 secs and 30 mins. Can anyone point me in the right direction?
I was only there a couple of hours this afternoon, I came away to try and arm myself with some information before I went back, so I haven't yet checked all the other fittings on the circuit. As all the other fittings are working fine I assumed it would have been a problem with fitting that is tripping the circuit.
Well yes high resistance could cause the circuit to trip.
have you checked all the other accessories on the circuit?
Fault finding is a art, could be solved in half a hour could take several hours. You need too be through and keep notes of all readings as you go to help spot any discrepancies. No right or wrong way, just work logically when you strip the circuit down.
Reply to MCB tripping help in the UK Electrical Forum area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
Which rcd is it? Is it one for everything, one for a few circuits?
