Mcb trips but tests clear | Page 3 | on ElectriciansForums
Discuss Mcb trips but tests clear in the UK Electrical Forum area at ElectriciansForums.net
Morsey
Wilts
Evening all
Let’s see if anyone can solve this one.
Recently wired a new extension. Today connected up ring circuit to 32amp mcb, all relevant dead testing done ir +999mohms and ring continuity.28 .28 .48. So all good turn mcb on and pop it trips off. Rechecked testing removed sockets just to double check for any small nicks etc all fine. Reconnect and turn on all seems fine. Hour or so later same problem. Replaced mcb all fine. Hour or so later same problem. Any ideas????
FYI nothing plugged in yet so no load whatsoever
Sounds like a cable between both points has been nailed/screwed etc catching the live and going into the fabric of the building what work has been carried out between the two points in time?
Reply to Mcb trips but tests clear in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
And fully tested it with an MFT obviously
