measurement of distribution | on ElectriciansForums
Discuss measurement of distribution in the Commercial Electrical Advice area at ElectriciansForums.net
P
pc electrical
could any one explain how this system works
there is 2 three phase meters, from there iv traced the cables to (1) 800a switch
how do the meters measure the 2 different loads??????
i have done a quick drawing
please see attachment
thanks
paul
  • [ElectriciansForums.net] measurement of distribution
That cannot work as drawn, the Cts need to be either around the supply lines to the individual loads, or if more than one supply is present around the supply lines themselves.
The voltage inputs to the meters as well as the meter supply itself (as opposed to the current inputs) may be before or after the isolator, or even commoned where one supply is used
yeah what iv drawn is what i can see..... common seance tells me this can not work but it is lol there must be something im not seeing. will have to go back to factory and investigate a bit more
The best way is via PhotoBucket if you have an account with them. Otherwise contact one of the moderators to give you permission to upload. Your post count may be against you.
This has got me interested so would like to see the set up.
Reply to measurement of distribution in the Commercial Electrical Advice area at ElectriciansForums.net
Sooo the client has accepted that we don't want to be fraudulently taking electricity so that worry is out of the picture. But now basically the...
5K
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
