Megaflo Y plan problem | on ElectriciansForums
Discuss Megaflo Y plan problem in the Central Heating Systems area at ElectriciansForums.net
Norfolk
Hi there,
I have a Megaflow wired to spec here (bottom of p21), i.e. in a Y plan with additional 2-port valve. When CH is on and the stat switches to satisfied, heating sometimes stays on, sometimes switches off as commanded. I thought it might be the 3-port's head so replaced that; is it maybe the programmer? That's a very old Honeywell ST712. I've checked the wiring - no faults that I can see there.
Help very much appreciated!
You are going to need a test meter. Guessing and observing no faults visually will not find an electrical fault.
It’s not like plumbing where a puddle will indicate the location of a fault.
Hi - I had a look at their diagram, and maybe it's just me but the 3 port valve white should probably be connected to the room stat - the missing link to pin 10. Just a thought.
[ElectriciansForums.net] Megaflo Y plan problem
Reply to Megaflo Y plan problem in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
