sparky1502
how would i conduct a pscc test on my 1552 meter any ideas ?
Discuss megger 1552 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This is incorrect! The approved method is:Stick both green and black probes on N and the red on L
PSCC is a high current, two wire test on a Megger 1552, Set test selector dial to PFC HI, with Red lead (or SPL1000 switched probe) connected to L and Green lead connected to N, press yellow TEST button on MFT (or SPL1000 if used), the MFT display shows the measured PSCC.
Reply to megger 1552 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
