Discuss MEM RCBO's in the UK Electrical Forum area at ElectriciansForums.net
May not fit older MEM boards. I tried a couple of months ago to find one, it was going to be materially cheaper to change the whole board.
Gonna be contraversial here, but if you file down the busbar a bit, the memshield 3 fit fine. I have considered the adverse effects etc. Etc.
GASP!Gonna be contraversial here, but if you file down the busbar a bit, the memshield 3 fit fine. I have considered the adverse effects etc. Etc.
After the lst suggestion that makes perfect sense mate.And if you snip a strand or two out of large conductors they fit in to smaller terminals perfectly!
Regardless of how little you file off, the manufacturers provide a certain size busbar rated at a certain current for a good reason. That reason isn't so you can adapt it to your requirements though.
Reply to MEM RCBO's in the UK Electrical Forum area at ElectriciansForums.net
