Menvier fire alarm | on ElectriciansForums
Discuss Menvier fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
how old is this fire alarm system? - Menvier fire system 6000.
.........i'm trying to upload a photo
ho wold do you reckon i am? that's about the same amount of info as you have given.
ohhh Series 6000....15 years old + ....discontinued but if its working fine. Only difference between this and modern panels, is a short circuit = fire,and not fault.... so the call points may not have 470 ohm resistors
No Mark some of these older systems, had no resistors just N/O contacts.....you may see this in some panel manual, stating set switch 1 for pre 1980 mode.
Nothing wrong with that, I recommend wiring the upstairs lighting direct from the shower via a pir, when you go into the bedroom to get your jammas on the shower will automatically start and warm the floor via a volt free contact so when you go to the loo afterwards you may get wet feet but they will be warm.
Reply to Menvier fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
