Metal flush boxes | on ElectriciansForums
Discuss Metal flush boxes in the Australia area at ElectriciansForums.net
C
chocolate
Does anyone know a tried and tested way of fixing a metal flush back box into a brick wall that has been completely mashed ( rather than a tidy bit of knocking out ) by a non-electrical tradesman ??????
Unfortunately, what remains of the surrounding brickwork is in no way secure enough to be drilled for a fixing.
I have a disheartened customer at the moment . . . . :(
GRIPFILL...........:eek:
For a few quid i would purchase a bag of bonding plaster or readymix quick set sand and cement and fill the hole, then push the box into it.
There really isnt any other option TBH.
Hi Chocolate
How many bricks have been damaged ? id say for neatness it shouldnt be to hard to scrap and replace neat cut bricks ! for the cost do a brick & plastering course saves lots of hassle.
Regards
Kung.
When i was doing houses we ofter had to put a few boxes side by side for various accessories, we used to nail a batten to the brick at the correct height then put some muck in and then push the boxes in, just makes it easier to get them level etc
Thanks for all the sound words of advice. A trip to B&Q for some bonding plaster as a first attempt to win the customer's confidence over to my side.
It's a old house - 1930s. The bricks ( no fault to the builder ) are brittle. One tap with a scutch chisel, and its biscuits crumbs. The mortar between beds is no better. In many places, its soft enough to push a finger into. I feel bad as I passed the repsonsibility over to someone else to do the hard labour on the walls.
Will try the bonding plaster - this sunday - and let you know the outcome !!!!
Reply to Metal flush boxes in the Australia area at ElectriciansForums.net
