View the thread, titled "Metal flush boxes" which is posted in Australia on Electricians Forums.
C
chocolate
Does anyone know a tried and tested way of fixing a metal flush back box into a brick wall that has been completely mashed ( rather than a tidy bit of knocking out ) by a non-electrical tradesman ??????
Unfortunately, what remains of the surrounding brickwork is in no way secure enough to be drilled for a fixing.
I have a disheartened customer at the moment . . . . :(
Once you realise you only mix a little at a time and use it quickly it's allright. Mind you, if you have a lot to do waiting for the stuff to set, may not be an issue.
top tip ,buy a bag of bonding adhesive ,the stuff they use to bond plaster board to block walls.
i use "lafarge" its white & sticks like **** to a blanket.:eek:
rip open top of bag and dump in yer shed/garage.
when its matured enough ie had a bit of damp it will go off solid in about half an hour which is ideal for setting boxes in crappy walls & hollow blocks.
to think i ****ed about for years with sand and cement waiting forever for it to dry.:rolleyes:
earth tail from socket to box lug good practice
elfyn
Reply to the thread, titled "Metal flush boxes" which is posted in Australia on Electricians Forums.
