Meter Block Circuits | on ElectriciansForums
Discuss Meter Block Circuits in the Electrician Talk | All Countries area at ElectriciansForums.net
skiandy
Is it still acceptable to run in new circuits by using meter block and installing a fused isolator? Its a small commercial job, 3 Phase.
Reply to Meter Block Circuits in the Electrician Talk | All Countries area at ElectriciansForums.net
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
Normally you'd install either a fuse-switch or a switchfuse at the incoming supply position rather than a DB, this gives you some hope of...
davesparks
even allowing for diversity this sounds a bit tight for a 100 amp supply, can you tell us what the existing circuits actually have connected to...
Thank you for your response. I really appreciate it.
It looked like the live connection side ( internally) burned against the neutral of the main switch
