Can the hive mind tell me where I can source the meter tail grommets that pack a 16mm insulated/sheathed tail up to 25mm? The Henley block knockouts are for 25mm cable and I want to maintain the IP rating for existing 16mm.
I may use heatshrink as a solution but I know these things exist because I’ve seen DNO/Meter fitters with them in the past
thanks in advance
T
thanks in advance
T
