Meter Tails Length | on ElectriciansForums
Discuss Meter Tails Length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
its
Recently, I've spotted this in a customers garage...
The main consumer unit in one corner of the garage and a garage consumer unit in the other.
The tails have been split with a henley block beneath the main CU and 25mm tails run up into the garage loft space, run over the beams unclipped, and down to the garage CU on the other side. The length of the tails is about 7mtrs. I've also noticed that the tails in the loft have been joined with another henley block which is just sitting there flapping about.
I've told the guy that this looks a bit dodgy but that I would check it out.
I reckon that it needs a main switched fuse on the DIY tails to put things right. Possibly replace the DIY tails with 25mm SWA? The garage CU is, after all, a sub-main. What do you reckon?
Hi and welcome to the forum:DSWA sounds the better idea and a lot safer.Sorry,just read the post again,what is connected to the garage CU.Might be a lot easier to resite the CU near the main CU.
The garage CU has got 32a Ring, 6a Lighting and 63a RCD incomer and he wants it to remain where it is so he can isolate the garage on his way out.
Reply to Meter Tails Length in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Normally you'd install either a fuse-switch or a switchfuse at the incoming supply position rather than a DB, this gives you some hope of...
davesparks
