Meter tails over 3 meters | Page 2 | on ElectriciansForums
Discuss Meter tails over 3 meters in the UK Electrical Forum area at ElectriciansForums.net
SW. London
Hello, anyone know when the regs recommending a switch fuse for meter tails greater than 3m long was introduced ? On older installations (about 20 years ago) was a switch fuse required on tails over 3m ?
433.2.2 concerns devices for protection against overload, however the next one (433.3.1 [iii]) concerns omission of devices for protection against overload, and says a device can be omitted "where the suppliers fuse affords protection to the part of the installation between the origin and the main distribution point of the installation where overload protection is provided" (The CU in this case). So that rules that out. Looks like it is the DNO rules regarding tail length
Only if the DNO agrees their fuse can be used.
I thought it was so the dno can guarantee the load is removed before pulling the fuse to isolate. If the trails go round the house then Henley blocked to an outbuilding or two they won't have a clue how to safely isolate.
I once calculated the clearance time of a 100a fuse on a 0.8 ohm efli (tn s) and off hand I've a feeling it was not quick enough, which would imply if it's bs7671 the 3m rule for omission of fault protection would apply.
Never mind the protection on the incoming supply, that's more than 3m long!
Reply to Meter tails over 3 meters in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
