Discuss meter tails who owns what in the Australia area at ElectriciansForums.net
just out of interest, if you want to change the tails to a sealed meter how do you go about it?Anything beyond the meter is the homeowners IMO
danny
Check out Durham sparks PIR pictures there you will see a notice on a cable head saying "It is dangerous and an OFFENCE to interfere with the apperatus" without breaking seals you cant change tails Get DNO out to fit a DP isolater
so to clarify if no isolator and meter is sealed it would make the tails DNO property?
danny
So the general concencus is: from meter to incoming side of DP switch belongs to DNO and from outgoing of DP switch is homeowners
danny
If that's the case, surely they should supply the 25mm tails and connect them to our CU.
Reply to meter tails who owns what in the Australia area at ElectriciansForums.net
